ArrmAh
I know this topic has been talked about a lot but here goes...I'm noticing my slipper clutch needs to be tightened after every run, sometimes mid pack, even with light street bashing. I've tried the loctite method (blue loctite) a few times with no success. I rarely attempt wheelies, maybe 3-4 times in my last session, so i don't really go full throttle. Only time i go full throttle is when i'm already rolling. So here's my current setup.
1) running 3s
2) punch levels stock
3) changed to 15T pinion
4) stock motor mount
4) 3.8 Proline Trenchers
5) Mainly running on grass and pavement
If my current rig/setup isn't the cause of my slipper clutch issues, would you guys recommend using a stronger loctite?
Thanks in advance
1) running 3s
Thanks in advance
