Any of you running spiral diff (AR220041) or spiral on 6s? (poll)
Straight ou spiral diff.?
  • Straight
    Votes: 1 100.0%
  • Spiral
    Votes: 0 0.0%
  • Total voters
    1
Thread starter #1
pl9171
Likes
18
Canada
Senton
Hi!
If yes, did you struggled to remove the rear diff. pinion? The 2,5 mm screw seems to be really hard to remove. (Input shaft cup screw… If I am correct ) Any tip?
Thanks
PL
Mr.Duke
Likes
843
NC
Outcast
If you switch to the spiral cut gear set make sure you switch out both front and rear at the same time. The Senton has straight cut teeth on both the 13t diff pinion and the 43t crown gear. The spiral gear set drops down to a 10t diff pinion and 43t crown gear. You can still run the lower geared spiral set, but to keep the same overall gearing you'll need to add a motor pinion with 4 more teeth to make up the difference
Thread starter #3
pl9171
Likes
18
Canada
Senton
Ok, great advice… The front diff is original. So i can maybe keep every thing original and install the spiral gear for futur project.
Thanks
PL
joostin420
Likes
965
MA/NH
Fazon, Kraton, Outcast, Senton
Why switch to spiral cut gears; is it just too loud?
Jerry-rigged
ArrmaForum Fan
Likes
1,578
Texas, Baby!
Kraton, Typhon, 4x4-Mega
Hi!
Thanks
PL
For that input cup set screw, use heat to break the thread lock.. Heat it with a soldering iron for 30-60 seconds, then try it.
Drtybird
Likes
74
Kraton
Whixh of the two pinions would be the strongest? I have heard people that run buggies they prefer straight cut
Drtybird
Likes
74
Kraton
Oh ..gears? That's was good you have to sacrifice one for the other.i think it's best to stick with the shim trick
Drtybird
Likes
74
Kraton
I am interested in the straight cut because of the different pinions. I am going to be running 1:5 wheels and tires, so I'll just wait to see what breaks
Similar threads
