Typhon Any reviews on HR aluminum gear case?
Niz55
Are these a good upgrade over stock HD cases? Are they compatible with m2c parts? Any negative side effects running these?
Thanks
Thanks
Absolutely a great upgrade. No failures since installing on my Noto 6s last summer (rear only). I run an M2C chassis and rear tower as well. I also use the stock Arrma cover, as I did not opt for the HR one since it's not sold as a set. Fit is good and I don't feel the cover was necessary.
Anyone know if I can use oven cleaner to remove the black anodizing on the HR parts and polish them .Want to match my m2c.
There are de-anodizing walkthroughs here at the forum. Check posta from @joostin420 at least.
I used sodium hydroxide which is inexpensive and can be purchased online. doesn't have anything other than the base itself in it.. *basically lye (pun intended)
Heres a quick link but can probably find it cheaper. https://www.amazon.com/dp/B013KMNCJU/ref=cm_sw_r_em_apa_i_qqytEbNSG95NW
Is Hot Racing in business anymore?
Hard to say. They’ve never responded to emails before and don’t have a listed phone number or physical address.
https://www.arrmaforum.com/threads/deanodizing-fun.7870/
This stuff looks so pretty deanodized and polished.
I am running the arrma metal diff cups is this going to be an issue?
