MysteriousPooper
11B baby
Thought plugs matched another rookie mistake. anyway to make these work? old plug on left new plug on right. going on big rock v3 stock motor
I think it’ll fit. Just align negative and negative.Thought plugs matched another rookie mistake. anyway to make these work? old plug on left new plug on right. going on big rock v3 stock motor
Wondered if that was an optionIs there a longer lead on the fan wires ¿ Looks like those plug terminals might match. Paying attention to placement, with small screwdriver or razor blade touch could lift the little plastic terminal retainers and slide the old wires out and place the new ones in their place.
So the 2 plug will fit into the 3? Judt have to make sure -- and ++ correct?I think it’ll fit. Just align negative and negative.
Focus on the - - alignment. You’ll be fine.Wondered if that was an option
Did not get power.Focus on the - - alignment. You’ll be fine.
It worked but in the pic you can see the wire broke loose. The polarity is aligned right according to +- pic on Amazon of new fan. It didn't click I will try pushing it in more. Can this fan be plugged directly into the receiver or does it need this extension?Are you sure the placement and polarity was the same ¿ Are the terminals pressed all the way in, you should hear a click. if so what about the fan voltage, and did the old fan work when you pulled it out ¿
Same thing with my new fan today, but they still are compatible. Just plug her in!Thought plugs matched another rookie mistake. anyway to make these work? old plug on left new plug on right. going on big rock v3 stock motor
Not other than trying to plug into receiver and the 3 prong cable. Any way i could get it power aside from that?Have you bench tested the fan yet to make sure it works ¿
Do the servo and esc work when plugged in ¿
No I don't think I have anything like thatDo you have a 12volt power supply ¿ usually you can dial the voltage down to the nominal voltage the fan is looking for and test it that way. Hopefully the receiver didn't short when the fan wire broke ¡
Yep the servo and ewc respondIf you have something around 7.4 - 8.4 volts, I believe that is nominal. Are the servo and esc working ¿
Okay I'll try itI would bench test the fan somehow. Kinda crude but if you have an old usb lead that your not using tou could cut it at the end of it. There will be a red and a black wire for positive and negative. Strip them back and that should give you 5volts when plugged in, might be enough to power it to see if it works. Paying attention again to polarity and not cross contacting.
