im wanting to run the wide dboots on the rear of the infraction, and to do so, from arrma site below.
anyone done this and knows if the handling is still good or not?
FRONT:
ARA311016 - MAIN INPUT GEAR 15T GP5
ARA311017 - MAIN DIFF GEAR 42T GP5
REAR:
ARA311018 - MAIN INPUT GEAR 14T GP6
ARA311019 - MAIN DIFF GEAR 45T GP6
Requires:
To use 107mm diameter tires on the rear axle of your vehicle and 100mm diameter tires on the front axle you must change the ratio of the gearboxes to account for the different rollout values. To do this use GP5 gears in the front gearbox and GP6 gears in the rear gearbox:FRONT:
REAR:
