Edough13
Bashing, Speed running and family!!
Hospitality Award
- Northern California, USA
- BigRock 4x4
- Granite
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Typhon 6s
- Vorteks
So last three times I've tried running my rig get a little running in and then after like 4-5 jumps pinion comes loose and slips forward. It's a steel 14t MOD1 ProTek pinion. First couple times just used screw with what loctite they put on grub screw bash around a bit then hit jump like 4-5 times and pinion comes off. Yesterday put some fresh loctite on grub screw, and yes waited a FULL 24hrs, took it out this evening and same $hit. Bashed truck around like 5mins then started sending her and again maybe 6-7 jumps in pinion came loose after landing. At a loss, tried different grub screw, loctite for 24hrs and same outcome. Think I'm going to throw stock 12t back on and see if it holds after loctite? Any input guys? Anyone run the ProTek 14t pinion also?
