Anyone ever heard of HRB brand batteries?
Brewcity414
King of questions
Wisconsin
Has anyone ever used this brand? Looking for a good battery along with run time...
https://www.amazon.com/HRB-50C-100C-Airplane-Quadcopter-Helicopter/dp/B06XKV4M5G/
Which battery would be the best to run on a 3s blx 4x4?
I've got a slew of HRB's Run time depends on your throttle use but I get decent times out of my hrbs I got nothing to complain about them
Only issue with SMC is there always out of stock so I never got to try there stuff.
I was of the belief that you should only get hard cases for RC cars.......was I miss lead?
I would say its more a personal choice, Hard case has the same internals as a soft pack just a hard case to protect it from damage in the event of a really bad rc crash and your battery gets punctured or something using soft..
I run mostly soft packs cuz i like to live on the edge :p Plus hard packs aren't always easy to find.
Two hard pack 2s and 4 soft pack 3s. I honestly never gave it any consideration, just what was available at the lhs when I was shopping for them. My first set of 3s gensacearespammers soft packs are just over a year old, no puffing, balance plugs intact, and I've switched the connectors twice.
I thought that would be too much for the 3s blx 4x4 ? at least that's what I've been told.
"Too much"? As in too big to fit? Or too much weight? The 5400 vs 4500 isn't a huge difference in weight, 4oz, but the larger one adds run time. The 5400 is 12mm taller.
I found a way to fit a SMC 3S2P 7200 in my stampede... had to get creative and use straps instead of the stock holder downer. Not sure how much room the granite has.
I made the 7200 packs out of some old 2S 7200 2S2P packs. Ended up being pretty tall.
LOL I did the same thing with my old stampede, cut the chassis and just threw on some velcrow straps to use my 7600's with it! :D
As in power the little blx100. That's just what I was told.
The battery is a supply, the ESC draws only what it needs. So long as the battery is the right voltage and fits, you can use it.
If you think of a water hose connected to a tank, voltage is the amount of pressure forcing water out and mah rating is the capacity of the tank.
Thanks for the analogy!
