Kraton ANYONE KNOW!!!
There are two different flavors of the Center Mud guard from 2 different sellers. One sits sandwiched between the C block and Bulkhead and the other sits forward of the C block screwed into it. If using Mud guards on the arms, clearance may be an issue or something to consider. Personally I would not sandwich the guard because the C block captures less of the hingepins based on the guards thickness. Placed forward of the C block and there may be input cup clearance issues and problem with set screw access. :unsure:
And dirt will enter behind the center guard anyway. I would just make a template and use thinner Lexan to experiment with. The center M guard seems functional but when used with the arm guards, fit and function may get critical.:unsure: The Arms are toed-in, so a center guard should be designed with a matching set of arm guards as a consideration.
https://www.ebay.com/itm/ARRMA-V1-V4-Kraton-Talion-Outcast-6s-2-pieces-Mud-Dirt-Rock-Guard/122704905999?_trkparms=aid=1110001&algo=SPLICE.SIM&ao=1&asc=225085&meid=44385487b08d45a98e7c91f4b6a64ffd&pid=100005&rk=1&rkt=12&mehot=pf&sd=123270759035&itm=122704905999&pmt=0&noa=1&pg=2047675&_trksid=p2047675.c100005.m1851
