I have asked the same question but got no response. I might give it a try if I can find a battery combo that will work without having to buy an 8S battery just for that.
I'm putting a Max6 in and was thinking about trying 8s with stock motor. Any advice?
No, just no. The stock motor is 2050KV, 8s would push it beyond 60K rpm! You'd want to look at long can motors with 1000 KV or less. But I personally wouldnt run 8S, the diffs are just not made for it.
Thanks for the help captain obvious.Have a spare motor handly for when it goes up in smoke. Stock motor is not made to run 8s. The KV is way too high and the motor is too small.
Lol, I meant running the Max6 and stock motor on 6S. I've read that some have done this, but I'm guessing that their motors or ESC's didn't last too long.
I think that that I have one picked out for when I want to switch to 8s a leopard 5892 1000KV, if that fits.
I'm kinda thinking about returning the Max6 I bought and getting the Max6 combo and gearing up. Any advice?
Read below I meant 6S not 8S lol. That was my original question, my bad.You were the one that asked this:
If my answer was so obvious, why did you post the question?
Well back in the day (wow I sound old) when we did speed runs, we’d use a mamba monster and a castle 1515 2200kv, and overvolted them both on 8s. Now, obviously neu castle motors are a much higher quality then hobbywing (they were hand built) but I don’t doubt the hobbywing 2050 can take 8s.I'm putting a Max6 in and was thinking about trying 8s with stock motor. Any advice?
You can’t run below 1000kv on a speed runner. That’s why nobody does. The motor turns so slow that you’d need to gear it so high there’s no gears available.No, just no. The stock motor is 2050KV, 8s would push it beyond 60K rpm! You'd want to look at long can motors with 1000 KV or less. But I personally wouldnt run 8S, the diffs are just not made for it.
Oh how speed running has changed.
For the modern speed runner I’d recommend running a 1730kv 4092 that’s Kevlar wrapped on 8s. Hobbystar has one.
