frankcfalco
- Infraction
I would like to try and hit 95 or 100mph if possible without going 8s. Anyone try a 34 or 35 tooth pinion gear?
Thanks,
Frank
Thanks,
Frank
Have you run it with the 27 tooth pinion yet? If not be-careful with the temps, fried my stock ESC but I might have been pushing it a little too much.I would like to try and hit 95 or 100mph if possible without going 8s. Anyone try a 34 or 35 tooth pinion gear?
Thanks,
Frank
I have. And 84MPH was awesome. But I would like to really push it to it's maxHave you run it with the 27 tooth pinion yet? If not be-careful with the temps, fried my stock ESC but I might have been pushing it a little too much.
I was actually thinking about running a Traxxas XO 1 body on it. Might be better AeroWelcome to Arrma Forum.
You may need to drop the spur gear down a bit to make more speed with your existing pinion and/or fit the larger pinion. Others may chime in here. I working on my Limitless. The spools are different. Some say the sweet spot is a 6s pack tweaked properly. The Infraction's body becomes a limit at some point above 70mph. To much drag to overcome. IMO.
Or get a limitless tooI have. And 84MPH was awesome. But I would like to really push it to it's max
I would get a Limitless body from JennysRc if yo want real speed with low drag. I considered an Infraction conversion for my Lim. chassis for change of pace. But, its more work than it appears to be. I got the Lim. for high speed reasons. The Infr. looks very nice, but its still a truck body. At higher speeds the truck tends to lift, crash and burn. Consider trimming the rear spoiler if you haven't yet for higher down force. Or even remove it altogether to test the difference.I have. And 84MPH was awesome. But I would like to really push it to it's max
I think that’s a better body than the Infraction or Limitless. What I am waiting for is the Delta GT body. It looks amazing.I know it’s a little heavy... but how about the unbreakable Bugatti body like I have. I can take a pic of it if you want? I’m not into speed running quite yet but just an idea. ?
Will a 35T pinion fit with the stock motor mount?I am going to try a 35T pinion this Saturday and see what top speed I get with the stock body. I will let you all know
I should know for sure buy Thursday. I ordered a 34t and 35t pinion.Will a 35T pinion fit with the stock motor mount?
Cool, let me know was curious about this.I should know for sure buy Thursday. I ordered a 34t and 35t pinion.
I think it should work! This gentleman was using a 30t Pinion and hit 96mph with stock electronics. He said he tried 34t pinion butthe ESC shut down. I am thinking playing with the Punch level may help with that. So I am thinking 100MPH should be possible. I will def know on Saturday if it doesn't rain.Cool, let me know was curious about this.
???????I think it should work! This gentleman was using a 30t Pinion and hit 96mph with stock electronics. He said he tried 34t pinion butthe ESC shut down. I am thinking playing with the Punch level may help with that. So I am thinking 100MPH should be possible. I will def know on Saturday if it doesn't rain.
Same thing happened to me, burnt up the ESC when I went up to the 27 tooth pinion.I think it should work! This gentleman was using a 30t Pinion and hit 96mph with stock electronics. He said he tried 34t pinion butthe ESC shut down. I am thinking playing with the Punch level may help with that. So I am thinking 100MPH should be possible. I will def know on Saturday if it doesn't rain.
Were you bashing it when the ESC burnt up? What was the punch level?Same thing happened to me, burnt up the ESC when I went up to the 27 tooth pinion.
Yeah, I pushed it a little harder then I should have. Punch level was stock.Were you bashing it when the ESC burnt up? What was the punch level?
Ah! Yeah I plan on only doing speed runs on the Infraction with the High gears. The other Infraction has a 21t and it is a sweet spot. It accelerates, drifts and bashes like an 18t, but hits 70mph.Yeah, I pushed it a little harder then I should have. Punch level was stock.
