basher27
I’ve been curious about purchasing some aftermarket cheap Amazon tires that I’ve seen. I have seen tires with wheels for around $20 for a complete set of four. I also noticed you have to glue them which that is fine. However the problem that I’ve been running into is they are either too large or too small. Has anyone discovered a said that works good with the Vendetta, I might be open to converting to 17 mm hex if it made sense to do so otherwise I have 12 mm adapters that I could put on so that’s not a huge problem. Thanks.
