- Colorado
- Infraction
- Limitless
- Outcast 6s
- Typhon 6s
thinking about gearing now and I kind of like the 46t spur suggestion. why 46t and which manufacturer is compatible? I did a few calculations; I want a capable head turning parking lot machine that is driveable, and not just in a straight line.
what about diff fluid weights; again I want driveable, and not just in a straight line?
thanx,
justin
I actually changed out my Center Diff gear/spur gear, with a 50t. Great acceleration, specially with the punch setting at 9, lose a bit of Top Speed... generally though I found it is great for less heating issues above all. I was very surprised how well that gearing ratio worked for just, all around bashing, that I think I will just buy a separate Center Diff housing and satellite gears, put the stock 46T (or whatever other speed run Spur gear) on the additional Center Diff and swap out each of the housing units when appropriate!
Hope that helps with any other ideas you've been pondering!
Edit: Sorry, I have right now, 30k Diff in the Front - Center has 500K - and Rear has 50K. Soo much more even power distribution, and even tire wear. Prior to the oil change in the diffs, I noticed I could drift, doughnut so much easier turning to the right then the left. After the Diff oil change, going either left or right it will now break and drift along along with feeling easier to break into a drift almost at any point of the turn now.
Hence, so far really liking this Diff Oil set up!
