That’s the one I have as well ????This is the most popular set up.
https://www.ebay.com/p/1065433521?i...-VV026mpqRYZ0rWjLsH_EXdhFXnc75ZhoCYxEQAvD_BwE
Although you can search motor fans with in the Forum and a few other threads will have some other options you can look into as well!! ?
Lil more expensive maybe in general, but the easy setup, screws, spacers, fans provided, I think make it worth it. Just pop on and go pretty much!That’s the one I have as well ????
If you want something cheaper I've got the Hobbywing fan that works great that you can make fit
Part number HW86080130
You will need to camp it so it can tighten down on the motor. I did it with my hands ??
Yes it cools down fantastic and the fan is durable, but for me I had to use a cheap plug extension because the fan wire is short (I used part number ET0731). You might not need it because (I think) you have a Limitless and the receiver and motor is much closer than on a Notoriousthis is much cheaper! thanks for great tip! but do i cool down good?
Hello i use this setup AR390205 BLX4074 2050kV 4 Pole 6S Brushless Motor + ARA390211IC BLX185 Brushless 6S ESC with IC5 need a tip wher i can buy fan that suite the engine ? can anyone help me?
later i will buy 2 X 6 lipo batterys.
If u want to put fans- NTF racing fans.
That is high end stuff... ???
All the other things i found so far is rubbish.
These fans are over rated imo only produce 5 cfm and the static pressure is poor you paying for alloy machined housing you can easily pick up a that is not only 40mm that runs at 15,000 but has 4x the cfm (cubic feet min) if air flow and static pressure is so good that can be used as a hockey puck there normally used in servers and have been for years rc fans are so overpriced,
People should look else where within the industry.
On my first build I found these to be awesome there 12v 6watt and at stock are 20cfm 4 x yeah racing flow as shown will run 4s so prob around 25cfm at this voltage
If you get it, screw the fan on the heat sink first before you clamp it, or the screws will not line up after. And remember to thread lock the screws when finished!
