ara330659 front upper alu holder
justin080
Germany, Meppen
  1. Limitless
  2. Typhon 6s
  3. Typhon TLR
Is the holder supposed that the screws are too long?
If yes I just will use some grub screws from saga gears 😄
I don't think it would matter as long as the body sits down on the front post
Of course but i wonder that engineering lol.
Maybe some can answer who has got a exb car and let me show if its supposed to be like that or they gave me too long screws.
They're beefier than the tiny 1.5mm grub screw that I've seen in those blocks 🤷‍♂️
I am talking about the screws lenght 😅 its too long.
Found a perfect solution.
My old typhon v2 had stock m3 grub screws what holds the shock pin. Arrma/HH has changed them to a buttonhead screw in all new models.
These screws fit perfectly.
See grub screw vs the screw which is supposted for lol.
Seems like that arrma really want that the screw should hang out lol.
Don't like that
I found a video where a guy upgraded typhon to exb parts and there You can see the same 💩 that the screws are way too long.
I first expected that the m4 pin notch was faulty (to less drilled away) on that exb part which holds the set screw on point.. but now i know it for sure😎
I am pretty much wondering while nobody said something about that problem.
videosource from pic :
Here you also can see with the included screws.
Car is from @Rcproponent
I remember that, that was a long time ago… haha
