crunchtime
- Granite
- Outcast 6s
- Vorteks
Do all of the ARRMA 6S generate about the same amount of noise?
Opened our new Outcast 6s EXB this evening. I'd say our yard is just barely large enough for the Outcast to not be too bad of a fit, but I didn't consider how much noisier it would be compared to our 3s trucks. Kind of bummed about it actually.
Now that I read about it, I find it's normal for ARRMA 6s and we just need to accept it. I'm not sure if it is mostly the pinion/spur gears, the magnets in the motor, the limited slip action in the center diff, or all the above. Well, I feel fairly sure that at least a chunk of it is the pinion / spur. Our neighbors are pretty cool, but if we do a lot of this it might become annoying to them when they're just trying to relax outside in the fairly quiet neighborhood.
I've been scouring this forum looking for ideas. I see some things that people have tried, maybe with a little improvement. But it seems mostly that people don't have a lot of success unless they swap out for a quieter motor. I'd be willing to try a plastic spur gear if it helped, even if I had to replace it once in a while as it gets trashed. Or maybe try to enclose the exposed pinion/spur gears with some sound insulating material, although I've read where someone tried that and it didn't make much difference.
I only ran with 3S so far. Two of our 3s 6000mAH batteries together didn't fit. I don't yet want to take them out of their hard cases. I don't yet have a 4S or 6S. The performance just on 3S wasn't actually as terrible as I expected. Even on 3s the steering wasn't always so great as the front tires wanted to lift (we knew this is a limitation of the OC due to the SWB).
I was kind of surprised how hot the motor got, even when we were running on 3S. It seems like ARRMA should have gone ahead and included it as part of the RTR package.
Anyway, if you have any ideas, I'm all ears.
