Catrinis4chaos
I was currently running 27/46 with a 1250kv motor. The hear was alittle sloppy on the motor shaft so I went to change the gear to a mod-1 35t pinion and its bigger so I'm only able to catch 1 screw. Is there anything I can get to secure both screws? Or what do you guys do that run bigger gearing on the felony? And what gearing do you run?
