Fireteam Arma fireteam a arm help
Also for anyone that hasn’t ran one of these… on the high speed pinion and punch turned up, I honestly cannot believe how fast this vehicle is… I mean like it’s stupid, not even a need for a upgrade, it’s extremely long and high, with shi tires, and it stands straight up, even if you hit it on dirt, got it for 400 on the Christmas sale
Looking to upgrade fireteam an arms, however I can’t find anything for sale listen fireteam, do they share the same arms as anything else ? Like the Mojave ? Or kraton 6s ? Thanks
Kraton 6S EXB arms
Did you check with JennysRC.com ?
She got the goods.
All wide arms are the same EXB/notorious v5+ design since 2022.
It’s a good failure mode, any structure you “upgrade” will transfer forces to the next weakest location. (Plastic bulkheads and hinge pin retainers)
Here's a negative recommendation.
RPM V1-5 rear a-arms may be the gold standard of arms with a V4 shock tower but with a narrow V5-6 tower the arms break easily.
Jenny's RC would be a good site to check
Be careful with that punch adjustment. Youll start twisting things apart if your too trigger happy.
