bukshypro
So this is a full, £90 metal diff from Arrma. I wanted to change the yoke to the red metal ones, but I also had to refluid the diff because we know Arrma (it was about 20% filled and with only 10k).
After re-assembling, the sides of the crown gear are not the same, so as I am turning the diff around, its binding a bit more on one side. It's doing it with the plastic yoke too, but not as much. the metal diff came with 3 shims, if I take them off, the binding is not there, but then there's a very little play between the metal input gear and the crown gear (way less than how much we want on the spur/pinion for instance). iirc, we want this to be as tight as possible.
here are some vids where you can see the play a bit; like how I turn it around one side always goes a bit higher, and that's what the input gear then binds, cuz input gear stays cool.
vids:
Slow mo vids:
To add: I took it apart, cleaned the case and all planetary gears and everything and build it back together and refluided it. It still binds.
I put it in the car too to see and I can definitely feel the binding when I roll the car.
Any tips ?
- my clues are: the shims are poop and maybe a bit bent? but shouldn't the whole diff and bearing just push them fully down?
- I might have overfilled (I actually did) the diff and so one side is bigger than the other? this clue because I tried to keep tightening the diff and so a bit of the play went away, but I cant keep tightening it more because the diff housing is just composite.
vids:
Slow mo vids:
Any tips ?
