- Thread starter
- #21
Yes, the bearings are fully pushed in. The red metal yoke is perfect fit, it goes in well and it stays there, but I can take it out without much struggle if I want.Are the bearings fully pressed onto each side? They should be flush up against the diff. I use a socket and the plastic handle of a screw drive to tap it tight. If all is good there…
Hold the input gear shaft and move the ring gear back and forth. A tiny bit of play is fine so if you hear a slight clicking sound you’re good. If there’s a lot of play, remove 1 of the shims and try again. Make sure you tighten the yoke screws well when testing it.
I will try the above, but the clue from my pictures was that the bottom outdrive seems to not be straight for some reason. if you look for perfect 90 , it is not.
