I've run out of about 30-40 batteries on my Big Rock and have the first major damage. The ring gear and bevel gear on the rear differential are completely worn out, the ring gear has massive tooth loss around the entire circumference. plastic shavings everywhere. I mostly drive on loose ground, I hadn't touched the setting of the slipper clutch, I tried it afterwards, it was 1.5 turns, as intended by the factory.
1st question: How can it be that after 30 rides the crown wheel is gone - I deliberately avoid wheelies and try to accelerate with a sense of proportion to avoid things like that.
I have now replaced the entire differential and found that the shim under one differential bearing was not installed on the ring gear side as shown in the exploded view, but on the opposite side. When reassembling, however, I had to reinstall the shim on the wrong side, otherwise the gearbox was very stiff and jerky. With the shim on the wrong side, it runs easily and without play.
2. Question: Can anyone confirm that the shim goes on the wrong side.
Going on with the slipper clutch: In the photo below you can see the output of the clutch to the front axle on the left, the output to the rear axle on the right - the one to the rear axle is also on the way to saying goodbye. I also swapped it. After only 2 batteries and a slipping clutch on 2 turns, you can see signs of wear again.
3. Question: Does anyone know the topic? What can you do about it? Now I've played with the slipper clutch. If I pushed the car forward with the hex key inserted (I think the method is well known), the wheels lock up at about 3 turns!!, not at 1.5 or less.
4. Question: What are the settings of your slipping clutches. Does the factory setting tend to be too hard or does my slipper have too much grip?
Looking forward to your suggestions
