slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
Arrma 6s shocks information.
How to rebuild Arrma 6s shocks.
Video curtesy of @TpPartsRcXtreme
The Arrma 6s shock eye to eye measurements are listed in post #2. https://www.arrmaforum.com/threads/...cks-upgrades-and-information.7413/#post-72395
Spring chart for most 4s and 6s models
https://www.arrmaforum.com/threads/...or-4s-and-most-6s-vehicles.18704/#post-286478
For rod end upgrades on the 6s shocks there are a few different options.
For different shocks on the V1-V4 6s Kraton, Outcast or Notorious you will want MT410 shocks.
Arrma Mega 4x4, BLX 3s and BLX 4s shocks.
How to rebuild the Arrma 4x4 shocks.
Video provided by @razorrc
@Camaroboy383 Had this to say and also found a nice mod to fix the shocks.
Here is a fix from @Camaroboy383 for the molded shock rod end problem https://www.arrmaforum.com/threads/3s-and-4s-guys-solution-to-molded-rod-ends.17061/
Optional shocks for the Mega, 3s and 4s models.
Some of the shocks listed below will require you to add a washer on the lower mount to keep the shock from rubbing the front driveshafts. I would try to find some washers that are about 2-3mm thick.
You can make the shocks the correct length by placing nitro fuel line under the shock pistons
https://www.amazon.com/rc-fuel-line/s?k=rc+fuel+line
Video curtesy of darkeclipticheart
Arrma alloy shocks.
These are a direct bolt on just use your stock shock springs on them.
Proline Racing shocks.
These are a direct bolt on but a bit expensive compared to a lot of the other options.
Hot Racing shocks Mega and 3s models.
YOU WILL RECEIVE:
- Two 2) rear shock bodies
- Two 2) Screw-on o-ring cap eliminates the plastic seal retainer
- Two (2) aluminum spring adjusters/collars
REQUIREMENTS:
- Silicone shock oil, assembly, bleeding, and installation per Arrma recommendations
- Existing stock shock components
Arrma Mojave shocks.
The best place to source these is from Jenny's Rc. Use the Axial bushings in the upper mount to take up the space.
Arrma Kraton/Notorious/Outcast 6s shocks.
Arrma Typhon 6s shocks.
HSP shocks.
A lot of people have used these shocks with great results. They are HSP Front 81003 and HSP Rear 81002 shocks. Use the affor mentioned Axial bushings in the shock caps. Remember that these are cheap Chinese shocks, they work okay but do not expect much for quality.
Big Bore eBay shocks.
Cheap ebay shocks these also need the previously mentioned Axial shock bushings. These shocks do not have bladders and can be a bit tricky to bleed, some users have had issues with the stock pistons having too small of holes, the rod ends are pretty poor, the shafts bend and they tend to leak.
Hot Bodies shocks.
Rather expensive and you will want to change out the springs. Also need the Axial bushings.
HPI Racing Big bore shocks.
Pretty much the same thing as the Hot Bodies shocks.(part numbers break down to be the same, except for the shock adjustment collars, they are different colors)
ZD Racing shocks.
Most users of these seem to pretty happy with these shocks. Spare parts for these are rather hard to find.
Tekno Racing shocks -
For Mega, 3s and 4s models you will want the shocks off the SCT410.
Team Associated RC8B3.1 shocks.
https://www.arrmaforum.com/threads/...rades-and-information.7413/page-9#post-307969
To install first you put the included insert in the ”giant hole”. Then you can insert the stock pivot ball after sanding down the ”ball” a little bit.
Hobao/Ofna Hyper SS shocks.
GPM Racing shocks.
3s models.
Arrma Vortex 4x4 BLX.
Arrma Limitless/Infraction/Felony
These will fit the front of the Vorteks.
Thanks to @Enferius being the guinea pig these springs look like they will work https://www.amazon.com/AXIAL-AX31284-Spring-40mm-6-3/dp/B012FV95PM
Arrma Mojave 6s shocks.
These shocks will only work on the rear of the Vorteks.
You will want springs pn ARA330637 these are the closest Arrma springs to the stock Vorteks spring in stiffness, they are slightly stiffer, 1.13N/mm (6.5lb/in) vs 1.06N/mm (6.05lbf/in) for the stock Vorteks rear springs, the springs are the same length 70mm.
Armma Talion 6s shocks.
These shocks will only work in the rear of the Vorteks.
Traxxas GTR Shocks.
Get VG Racing springs. https://www.vgracing.com/product/GTR_Springs.html
Proline PowerStroke shocks for the Slash.
Proline Pro Spec shocks for the Slash.
Losi Tenacity DB Pro shocks.
These are just like the cheap eBay shocks for the Granite listed above with all the same problems.
https://www.ebay.com/itm/283944199963?hash=item421c64a71b:g:2yoAAOSwal5YLnxH
ZD Racing Shocks.
Looking at the Q/A and reviews the springs might be on the soft side.
https://www.amazon.com/dp/B08H5C93F...NRJPKYRAGVBQ?_encoding=UTF8&tag=arrma-20&th=1
General shock info.
Whenever working with shocks it is always a good idea to have a pair of shock shaft pliers, there is a Tekno set listed further down that works really well and is made extremely well, but it is rather expensive, for those who are on a bit of a budget you can always get these Trackstar shock tools https://hobbyking.com/en_us/shock-tools.html I have this set and have used it a lot it makes shock assembly/disassembly so much nicer. Another nice tool to have around is a shock caddy/stand for when you are filling your shocks. Many companies make these so there are many options https://www.google.com/search?q=rc+...-O_kAhVnJDQIHZtID34Q_AUIFygA&biw=2560&bih=888
These are things you will want for putting Tekno shocks on your 6s model, the Tekno locking shock rod ends also work on most of the above listed shocks and will fit on the Mega, 3s and 4s models with aftermarket shocks.
There are some differences in the kits as well.
If upgrading the shocks on a Kraton, Outcast or V1/V2 Talion I would say go with the E/NT48 shocks, If you can find them the E/NB48.4 shocks have emulsion style caps.
I have not looked into or tested the new E/NB48 2.0 shocks so your results may vary.
Official Tekno shock build video
Official Tekno emulsion shock build video
Rc shock mount positions explained.
Video Curtesy of @razorrc
Tekno truggy spring rate chart
Tekno buggy and SCT410 spring rate chart
Just to show the color differences in the shocks.
From left to right MT410, NB48.3, Arrma Outcast front and rear & Tekno ET48.3
Tekno MT410 front vs Arrma Outcast front.
Tekno ET48.3 vs Outcast rear.
More threads about the Tekno shocks.
https://www.arrmaforum.com/threads/...my-mind-bought-tekno-full-option-shocks.4120/
https://www.arrmaforum.com/threads/tekno-shocks-on-kraton-i-had-no-idea.4064/
https://www.arrmaforum.com/threads/why-you-too-need-tekno-shocks.4074/
- Nero HD shock rod ends ARA330338 https://www.amainhobbies.com/arrma-...zzjCB25MNdPFeCIvrM6aiH2Uhb75qajHEBRFs2OT68cq8
- Arrma Mojave shock rod ends ARA330608 https://www.amainhobbies.com/arrma-...IxZ7K3Sw2M8JtfBUwrqH0Qz0HkZpUeHxoC7JEQAvD_BwE
- Tekno shock rod ends with locking perches https://www.amainhobbies.com/tekno-...x9r-j9IS7K8TSlcTVPJT_X3_ZThisupxoCSiAQAvD_BwE
- Front 122mm eye to eye
- Rear 137mm eye to eye
- MT410 https://www.ebay.com/itm/TKR5603-TE...559090&hash=item5499956190:g:5~EAAOSw9PFb0rvE
- Stock front shocks for the Senton, Granite, Typhon, Big Rock Crew Cab Mega and BLX 3s are 100mm eye to eye.
- Stock rear shocks for the Senton, Granite, Typhon, Big Rock Crew Cab Mega and BLX 3s are 115mm eye to eye.
- Stock front shocks for the 4s models are 106mm eye to eye.
- Stock rear shocks for the 4s models are 121mm eye to eye.
The issues with the 3s and 4s shock line is the way they are manufactured for assembly.. the o-ring housing has a lid that snaps on to compress the o-rings, the pressure exerted on the o-rings is not enough to properly seal the shaft.. a washer or two can be added to the assembly under the plastic cap to compensate and add more pressure... only so much pressure can be added before the cap doesn't latch anymore, wish they had molded a land for the cap to sit against when tightening, many of the leaky shock issues we see wouldnt be a problem.. the hr shock bodies do incorporate the land machined into the body to provide adequate pressure for sealing, as well as nice o-rings...
That being said my biggest gripe about the 4s and 3s line isnt the leaking, its the shock shafts with the molded rod ends... ? I'm waiting on some standard style 4mm shafts, and will be using the nero 6s rod ends and spring perches...it will be so nice to just unscrew the rod end and install a new one.. (if they even break anymore)
Another thing to note if changing the shafts or switching to the hr bodies is that the land for the piston is not deburred from the factory.. they have an extremely sharp hard edge and can tear the o-rings on assembly if not careful... I typically take some 800-1000 grit and knock back that hard edge so I know for sure no matter what they wont tear at the o-ring..
The following shocks are not compatible with the Arrma Vorteks 4x4. Vorteks shocks are listed at the bottom of this section.
For the upper mount when using other shocks on your Mega, 3s or 4s model use Axial part number AXA1356 https://www.amazon.com/Axial-AXA1356-Silicone-Shock-Bushing/dp/B0051W7R1M
Arrma alloy shocks.
- Front - https://www.prolineracing.com/performance-parts/power-stroke-shocks-arrma-front.asp
- Rear - https://www.prolineracing.com/performance-parts/power-stroke-shocks-arrma-rear.asp
YOU WILL RECEIVE:
REQUIREMENTS:
- Front https://hot-racing.com/?partnumber=ATF155AF08;c=1345
- Rear https://hot-racing.com/?partnumber=ATF155AR08;c=1345
- Front https://hot-racing.com/?partnumber=TFF155AF08;c=1428
- Rear https://hot-racing.com/?partnumber=TFF155AR08;c=1428
- Fronts these go in the front 108mm eye to eye.
- Mojave https://jennysrc.com/collections/ar...ks-assembled-dampers-springs-4mm-hd-ara7604v2
- Mojave EXB https://jennysrc.com/collections/ar...ks-assembled-dampers-springs-4mm-hd-ara7604v2
- Fronts these go in the rear 115mm eye to eye
- Kraton 6s socks https://jennysrc.com/collections/ar...st-assembled-dampers-springs-red-new-ar106040
- Kraton 6s EXB shocks https://jennysrc.com/collections/ar...bled-dampers-springs-4mm-2020-arrma-ara106053
- Notorious https://jennysrc.com/collections/ar...hocks-assembled-dampers-springs-red-ara8611v5
- Outcast EXB I will post these once available.
- fronts 104mm eye to eye https://jennysrc.com/collections/no...-springs-red-ara8606v5?variant=32972236685366
- rears 117mm eye to eye https://jennysrc.com/collections/no...pers-springs-ara8606v5?variant=32972252708918
HSP shocks.
- fronts are 110mm eye to eye.
- rear are 130mm eye to eye.
- https://www.ebay.com/itm/292516649785?ul_noapp=true
- fronts are 102mm eye to eye.
- rears are 114mm eye to eye.
- https://www.ebay.com/itm/BIG-BORE-A...293293?hash=item41fb32ee6d:g:lMkAAOSwHMJYLnYG
Hot Bodies shocks.
- front 100mm eye to eye https://www.amainhobbies.com/hb-racing-112mm-big-bore-shock-set-hbs113466/p413226
- rear 112mm eye to eye https://www.amainhobbies.com/hb-racing-124mm-big-bore-shock-set-2-hbs109830/p250768
- front 97mm eye to eye - HPI 101115 https://www.ebay.com/itm/VORZA-HP-R...188772?hash=item4d76a7c724:g:Gp4AAOSwyARbNkk6
- rear 112mm eye to eye - HPI 101116 https://www.ebay.com/itm/HPI-Electr...729592?hash=item2f3894a8f8:g:BC4AAOSwaC5gdLE1
ZD Racing shocks.
- Front: 110mm eye to eye https://www.banggood.com/2PCS-8001-...rmmds=detail-bottom-alsolike&cur_warehouse=CN
- Rear: 132mm eye to eye https://www.banggood.com/2PCS-8002-...-Rc-Car-Parts-p-1436241.html?cur_warehouse=CN
- Front 107mm eye to eye https://www.ebay.com/itm/NEW-TEKNO-...536456&hash=item21380b15c6:g:-usAAOSwNkJaFNV-
- Rear 122mm eye to eye https://www.ebay.com/itm/NEW-TEKNO-RC-SCT410-3-Shocks-Rear-TKR6016-NS28/312082133925?_trkparms=aid=333200&algo=COMP.MBE&ao=1&asc=40719&meid=299a715cf17a4671976e083a26ba3c67&pid=100008&rk=1&rkt=12&sd=142674171334&itm=312082133925&pmt=1&noa=0&pg=2047675&_trksid=p2047675.c100008.m2219
- Eye to eye measurements are currently unavailable. https://www.ebay.com/itm/ASC80935-T...067752&hash=item421652ed01:g:~IQAAOSwYyVZesaE
- Front 108mm eye to eye https://jennysrc.com/products/hobao...os=22&_sid=54fba704f&_ss=r&variant=8368405187
- Rear 125mm eye to eye https://jennysrc.com/collections/hy...88097-1-87126-90056-ofna-1?variant=8613044099
- Front total length 115mm end to end https://www.ebay.com/itm/NEW-OFNA-H...937454&hash=item21348466ea:g:vSkAAOSwk~ZaH09p
- Rear total length is 135mm end to end https://www.ebay.com/itm/NEW-OFNA-H...245274&hash=item48a51c239f:g:ex8AAOSwO7haE7RD
GPM Racing shocks.
3s models.
- Fronts 102mm eye to eye https://www.gpmparts.com/arrma-gran...damper-102mm-6pc-set-gpm-mag102f-p-13646.html
- Rears 115mm eye to eye https://www.gpmparts.com/arrma-gran...damper-115mm-6pc-set-gpm-mag115r-p-13707.html
- Fronts 107mm eye to eye https://www.gpmparts.com/arrma-krat...pers-107mm-10pc-set-gpm-maks107f-p-24427.html
- Rears 120mm eye to eye https://www.gpmparts.com/arrma-krat...pers-120mm-10pc-set-gpm-maks120r-p-24428.html
- Stock front shocks for the Arrma Vorteks are 87mm eye to eye.
- Stock rear shocks for the Arrma Vorteks are 109mm eye to eye.
- Rears 85mm eye to eye https://jennysrc.com/collections/ar...assembled-dampers-springs-infraction-ar109011
- Fronts 108mm eye to eye https://jennysrc.com/collections/ar...ks-assembled-dampers-springs-4mm-hd-ara7604v2
- Fronts 107mm eye to eye https://jennysrc.com/collections/ar...rings-dampers-ar106048?variant=20329031565366
Traxxas GTR Shocks.
- Fronts 87mm eye to eye https://www.ebay.com/itm/274394584293?hash=item3fe33114e5:g:KS0AAOSwSWde4oZc
- Rears 103mm eye to eye https://www.ebay.com/itm/192771284109?epid=1203434569&hash=item2ce2105c8d:g:ksYAAOSwgYBggyYs
- Fronts 88mm eye to eye https://www.prolineracing.com/performance-parts/power-stroke-shocks-front.asp
- Rears 102mm eye to eye https://www.prolineracing.com/performance-parts/power-stroke-shocks-rear.asp
- Fronts 88mm eye to eye https://www.prolineracing.com/performance-parts/pre-assembled-pro-spec-shocks-front.asp
- Rears 100mm eye to eye https://www.prolineracing.com/performance-parts/pre-assembled-pro-spec-shocks-rear.asp
- Fronts 85mm eye to eye https://jennysrc.com/collections/lo...-desert-buggy-los03027?variant=33054087774262
- Rears 100mm eye to eye https://jennysrc.com/collections/lo...-desert-buggy-los03027?variant=33054116446262
ZD Racing Shocks.
- Rear 105mm eye to eye
General shock info.
- Tekno Locking Shock Rod Ends TKR6140B
- Tekno Rc Aluminum 6.8mm Pivot Balls TKR5049A
- 2x Tekno shock standoffs TKR5527.
- 4x M4 nylon lock nuts.
- 4mm drill bit to drill out your shock towers.
- blue thread lock.
- shock oil of your choice.
- TKR1115 (optional but recommended).
- Everything below this line is for V1-V2 or 2014-2017 models, 2018+ models disregard this section.
- Arrma Shock Springs 85mm 6.2 lbs/in AR330507
- Arrma Shock Springs 95mm 5 lbs/in AR330508
- Or
- Tekno Shock Springs Orange 1.6x7.5T 6.11 lbs/in
80mm TKR6093 - Tekno Shock Springs Orange 1.6x9T 90mm 4.8 lbs/inTKR6083
- TiNi Coated Shock Shafts front for ET48.3(rear for SCT410) TKR6017T
- TiNi Coated Shock Shafts front for SCT410 TKR6004T
- TiNi Coated Shock Shafts rear TKR6061T
- Tekno CNC Delrin Shock Cartridge Set TKR6146
- CNC Delrin Conical Shock Pistons TKR6050: 10x1.1mm
- CNC Delrin Conical Shock Pistons TKR6051: 8x1.3mm
- CNC Delrin Conical Shock Pistons TKR6052: 10x1.2mm
- CNC Delrin Conical Shock Pistons TKR6053: 8x1.4mm
- CNC Delrin Conical Shock Pistons TKR6054: 10x1.3mm
- CNC Delrin Conical Shock Pistons TKR6063: 6x1.5mm
- CNC Delrin Conical Shock Pistons TKR6064: 6x1.6mm
- CNC Delrin Tapered Shock Pistons TKR6159 4x1.8mm
- CNC Delrin Tapered Shock Pistons TKR6160 blank
- Aluminum Vented Shock Caps TKR6003
- Emulsion/Vented/Standard Shock Caps TKR8702
- The MT410 kit has composite shock caps, cartridge caps and shock collars.
- The E/NB48 and E/NT48 kits come with aluminum shock caps, cartridge caps and shock collars.
- The MT410 kit comes with molded pistons only.
- The E/NB48 and E/NT48 kits come with cnc pistons and molded pistons.
- The E/NB48 machined pistons are different from the E/NT48 pistons.
- The springs with the E/NB48 shocks are different from the MT410 and E/NT48 shocks.
- The MT410 and E/NT48.3 come with green rate springs.
- The E/NB48.4 comes with black rate low frequency springs in front and orange rate low frequency springs in rear.
- The spring perches on the E/NB48 shocks are shorter than the MT410 and E/NT48.
- Shock bodies are different colors.
- The E/NT48.3 come with none vented shock caps
- The E/NB48.4 come with Emulsion/vented/none-vented shock caps
- Tekno fronts are 3mm longer than the Arrma fronts.
- Tekno rears are 5mm shorter than the Arrma rears most of this is do to the rod ends.
