Arrma 8s throttle reversed
Rbftp83
Hey so I just set up my roller fairly new to this when I got it all together realized throttle was reverse. I'm wondering if it's possible I plugged the throttle wire from esc into reciever flipped. I know motor wires into esc are in the right order but for now I went into esc settings and reversed motor and it seems to be fine will this be okay
Rob66
Yeah nah!
ArrmaForum Fan
Hospitality Award
Potsdam, New York, (You-S-Eh)
  1. Infraction
  2. Kraton 8S
  3. Kraton 6s
  4. Mojave
  5. Mojave EXB
  6. Outcast 4s
  7. Senton 3s
  8. Talion
  9. Typhon 3s
Some times the motors need reversed. ESC can't be pluged in to the receiver backwards.
Just reverse the motor in the ESC, like you did and you will be fine.
Running sensored ?
Rbftp83
No its not sensored its all spectrum stuff I tried reversing on the esc but the my gas was still reverse I don't really want to reverse transmitter cause forward seems under powered and reverse over powered. I just wanna drive this darn thing lol
I want to try the motor wires just unsure which 2 to swap
Rob66
Yeah nah!
ArrmaForum Fan
Hospitality Award
  1. Infraction
  2. Kraton 8S
  3. Kraton 6s
  4. Mojave
  5. Mojave EXB
  6. Outcast 4s
  7. Senton 3s
  8. Talion
  9. Typhon 3s
Swap any two motor wires and the it will run in the correct way.
Rbftp83
That's what I did and it should be fine right? I was going to try binding it again maybe.
I'm trying to get used to this dx5 rugged transmitter as well it can be a bit confusing.
Thank you
Rob66
Yeah nah!
ArrmaForum Fan
Hospitality Award
  1. Infraction
  2. Kraton 8S
  3. Kraton 6s
  4. Mojave
  5. Mojave EXB
  6. Outcast 4s
  7. Senton 3s
  8. Talion
  9. Typhon 3s
Yes, Reversing the steer servo is fine because servo is linear both ways, as your ESC if you reverse the throttle you might end up with car going forward and the ESC is getting reverse signal, this means the car will go faster in reverse then forward.
Hope this make sense.
Rbftp83
It does and thank you.
