- Granite Grom
- Infraction
- Kraton EXB
- Senton 3s
I have the aluminum center diff case is my kraton and it still leaks any thoughts I believe i put all the shims and all that stuff that it came with
I was asking if you are running EXB LSD diffs or the RTR standard Open diffs? These use 2 different Alloy diff cups.It’s the red one with the arrma logo don’t know if its the exb one don’t believe the package said exb it has the 8 screws it looks to be leaking from the dogbone cups ill put photos tomorrow ore later today when i have a chance
I believe it said to add extra shims and i did add them it there a rubber spacer im missing or something?
I’m using the stock one it came with two anti leak pads put both on maybe that’s the reasonI was asking if you are running EXB LSD diffs or the RTR standard Open diffs? These use 2 different Alloy diff cups.
I have the standard oneStandard/non EXB diff case
29mm EXB diff case:
Can you tell where it's leaking from?
I was doing it when I underfilled it too^^^
+1
If Overfilled, then extreme pressure will blow out Oil past the O-rings in most cases.
Man I literally built it yesterdayMy suggestion is to pull the diff out and examine it. Too hard to tell while it is installed - or just pull it and rebuild, paying careful attention to the o-rings and gaskets and hopefully that solves it.
