- Wisconsin
- Felony
- Fury
- Granite
- Infraction
- Limitless
- Kraton 8S
- Kraton 6s
- Kraton EXB
- Kraton 4s
- Nero
- Notorious
- Outcast 8s
- Outcast 4s
- Raider
- Senton 6s
- Talion
- Typhon 6s
- Vorteks
ARRMA-CUSTOM TYPHON SCORPION (8S-ELECTRONICS) - NEW
- Specifications:
Drivetrain: 4WD (5mm) Shaft Drive
FANS: TWIN 40MM TORNADO FANS SET ON MOTOR
Final Drive Ratio: .85:1 Ratio with 34 tooth pinion and 29 tooth spur gear)
Max Battery Dimensions: 5.5 x 1.8 x 1.5 in. (139 x 46 x 39mm)
Motor Size: 4092-2300 KV Sensorless Brushless Motor (INCLUDED)
Motor Type: TP 4060CM (4092) Sensorless Brushless (INCLUDED)
Radio: FS-GT5 6CH RC Transmitter with FS BS6 Receiver(INCLUDED)
Servos: CLS6331 30KG High Torque RC Digital Servo (INCLUDED)
Shock Type: Big Bore aluminum body oil-filled
Size/Scale: 1/7
Speed Control: HOBBYWING EZ RUN MAX 5 8S ESC (INCLUDED)
Suspension: Independent
Tire Compound: White compound
Tires: deBOOTS 1/8 BELTED TIRES - Optional Tires: CONJB38B Contact GT8/Rally 1/8 On Road Foam GT Tires 38 Shore Black rims GRP
Vehicle Type: Speed bash on-road TYPHON chassis
Weight: 20 lbs (with batteries)
Wheel Diameter: 6.65" (169mm)
Wheel Hex Size: 17mm Hex
LENGTH: 20.08" (510mm)
WIDTH: 12.22" (310mm)
HEIGHT: 7.48 (190mm))
Wheelbase: 12.91" (377mm)
Includes:
1.) 1/8 TYPHON CHASSIS
2.) HOBBYWING EZ RUN MAX 5 8S ESC (INCLUDED)
3.) 1-PC: Powerhobby 8S 29.6V 5000mah 100c Battery
4.) TP 4060CM 4092-2300KV Sensorless Brushless Motor
5.) Steel Mod 1.0 34 TOOTH Pinion Gear / 29 TOOTH SPUR GEAR
6.) Racing Heat Sink with TWIN Tornado Electric High Speed Fans set for 1:8 Motors
7.) SPEKTRUM® SPMS652 DIGITAL High Torque Waterproof Servo
8.) EXB ALUMINUM STRUTS (INCLUDED)
9.) SPEKTRUM® SLT3® RADIO Transmitter with SPEKTRUM® SR315 RECEIVER 3-Channel Receiver (INCLUDED) - 10.) Tires: deBOOTS 1/8 BELTED TIRES (INCLUDED)
- Needed to Complete:
AA ALKALINE BATTERIES FOR TRANSMITTER
WARNING
THIS IS NOT A TOY!
The special electronics and gearing in this ARRMA Typhon makes it a very powerful machine. It is capable in reaching speeds in excess of 100 mph and warrants special experience in handling it.
It is recommended that the operator start off with either a 4 cell or 6 cell battery and use caution in bringing it up to full speed before going the the 8 cell (maximum) battery.
Seller is not responsible for any property damage, equipment failure or personal injury due to the misuse of this product. Buyer uses at his or her own risk. -
- CUSTOM BUILD OF ARRMA TYPHON SCORPION VIDEO LINK ON YOU TUBE:
$1450.00 + FREIGHT (REDGRANITE, WI 54970)
(OR MAKE ME AN OFFER)
