Hmm...Popped a front drive shaft today, i adjusted the slipper when i first got the truck and the end points for turning. But after about 20packs one gave up. Should i run the arrma cvd or the hot racing. Arrma is cheaper but is still plastic. Lmk
Correct they are different so you would not want to sway them. If so, this would lead to a death. Since you are a low basher get the set first before upgrading. Need a new set anyway and this is the cheaper way.I don't bash like you guys do, last time i had it apart it loooked like the u joint yokes were getting thin from rubbing on each other from turning
Also, after looking at that link i see that the front and rear driveshafts are two different part numbers. As stated up above when i had it apart last i noticed wear on the front shafts. So i swaped the rear to the front and front to the rear. I didnt notice a difference. But maybe this is why it broke?
