- Kraton 4s
- Raider
Totally.Arrma's killing it with all these new releases!
Or just go all four rear tires
OMG they made the fronts 100mm and the rears 107mm tall.
More burnt up center diffs and now you cant run this with a spool
They have different diffs f/r to accommodate for the different wheel speeds.
They also made the F/R diffs have different ratios, so the rollout works with the odd tire sizes...
Oh sweet!!!! Although now you cannot use GRPs/Aftermarket tires without swapping the diffs.They also made the F/R diffs have different ratios, so the rollout works with the odd tire sizes...
Screen grab from the RC Sparks vid -
Full vid -
