So I got me a used arrma felony but the original owner put the smaller tires in the back as well without switching the diff. Would it be alright to run it a few times till i get new tires orderd or no?
Yeah that is a good point. But do think it will be safe to run it till I get one tho?I would buy a new rear diff and not a new set of tires.
YeahMaybe? IDK I am guessing it would put a little strain on the diffs and a lot of wear on the wheels. If the previous owner drove it this way, it probably wouldn't do any noticeable difference on the gears.
No not correct. Run it if you want. Will not drive optimally at all. I myself would not enjoy doing it that way . Just me. Give it try.So I got me a used arrma felony but the original owner put the smaller tires in the back as well without switching the diff. Would it be alright to run it a few times till i get new tires orderd or no?
I ran it and it's like perfect for speed running. It creates like a pull effect in the front. Orderd me new rears so I guess I'll go burn off the tires for one last time before I put it up for the season.No not correct. Run it if you want. Will not drive optimally at all. I myself would not enjoy doing it that way . Just me. Give it try.
I imagine the old owner didn't know what he was doing.
Yeah just need the matching front diff at the rear to run 42/100 hoons all around. Making it an Infr. And you will be good. Runs better than a Stock Felony would. Might look funny with narrow rear wheels and the wide Felony body. That's all.
The 53/107's taller Fel. Hoons don't have the best traction. I suggest getting them in Gold Compound it you do. I have a set of the Whites
