Raider Arrma fury 2wd 2014
Aclewis
Warsaw ky
  1. Talion
Hey y’all, just got a used 2014 fury, I got it real cheep but needs a shock, I decided I’ll just replace them all, can anyone lead me in the right direction for a good set of upgrade shocks?
I know @Aussie RC Playground used some Trackstar shocks on his Raider, but I can't remember which ones. Do you happen to have an eye to eye measurement of the stock shocks?
Can anyone help me find the stock shocks, I can’t find them on any sites?
So far I think found the eye to eye measurements for them as I would assume they are the same as the Fury.
Front are 78mm eye to eye
Rear are 98mm eye to eye.
I did find this thread https://www.arrmaforum.com/threads/affordable-1-10-scale-aluminium-shock-upgrade.67/
I found the ones Vas used. But the fronts are out of stock. ?
Front https://hobbyking.com/en_us/alu-shock-absorber-set-35mm-12x85mm-2.html
Rear https://hobbyking.com/en_us/alu-shock-absorber-set43mm-12x100mm-2.html
I found these on Aliexpress https://m.aliexpress.com/item/32846083834.html?spm=a2g0n.seo-amp-detail.productBottomBar.viewDetails
