I have someone that nees a Fury MEGA fixed. It's missing a rear right dogbone, and an outer screw that holds the rear right camber link on. I found the parts, I'm just not sure if they're the correct parts.
83mm Dogbone, not sure if I need the 80mm or the 83mm. Again, it's the rear right dogbone.
https://www.horizonhobby.com/product/dogbone-83mm-2/ARAC4026.html
Ball Stud. Not sure if this is the right size. Again, it's for the outside of the rear right camber link.
https://www.horizonhobby.com/product/ball-stud-4.3x13mm-2/ARAC9815.html
Maybe these links will help you help me.
https://www.arrma-rc.com/pdf/exploded-views/AR102651.pdf
https://www.arrma-rc.com/support/downloads/FURY/ALL/ALL
https://www.arrma-rc.com/pdf/xref/arrma-parts-xref-A_AR102651.pdf
Thanks!
@biggman100
Thanks!
@biggman100
