Alfadiablo
- BigRock 4x4
I noticed that the recommended front is 100mm and the rear is 115. Is there are any real difference other than ride height if this was different? I've noticed that the arms give more free play movement when the shocks are removed does anyone know if this plays a negative part on performance or can the extra space be used with longer or more dense shocks like 6s compatible ones? I want to make sure before I take the plunge. For example, the 6s typhoon front shocks I'm looking at are 115mm double section springs where the rear ones are 135mm. Would this not fit? Or be too wild if I did try to fit them?
