Hey noob question here, but I'm confused about how the typhon shocks can work well for the Granite. Aren't the typhon shocks MUCH stiffer, since they're meant for a much heavier vehicle? I think the typhon shock springs are in the 6lb per inch range, and the shock oil must be heavier as well.
They work well because it's basically a hot swap with the exception of needing a couple spacers in the rear so the spring doesn't rub against the driveshaft. You can adjust the preload and also change to a lighter or heavier fluid to get to where you want dampening wiseHey noob question here, but I'm confused about how the typhon shocks can work well for the Granite. Aren't the typhon shocks MUCH stiffer, since they're meant for a much heavier vehicle? I think the typhon shock springs are in the 6lb per inch range, and the shock oil must be heavier as well.
Can someone explain how we can just bolt on shocks from a much heavier vehicle (i.e the Typhon) while still having the lighter vehicle (the Granite) drive correctly?
Thanks!
PS I believe folks on the forum who says this will work, but I am just curious to hear an explanation for HOW it works out.
I’ve recently encountered this problem and wondering why I have to pet load my shocks so far. What springs would you recommend to replace the typhoon springs? What’s the stiffest you can use?The Typhon shocks work well for a Granite because they have very similar length.
https://www.arrmaforum.com/threads/...d-blx-4s-shock-information-and-upgrades.7413/
But the Typhon shock springs are nowhere near the 6lb/in range. The Granite 3s shock springs are much stiffer. Yes, the Granite is lighter, but it's a monster truck meant for bashing/jumping. The Typhon is more of a racing buggy. Racing buggies use really light springs. Yes the larger shock body and more oil make a difference, but not enough to make them stiffer. YouTubers using Typhon springs to bash/jump a Granite have the pre-load collars really tightened down. You'll get much better performance with stiffer springs. Trust me, I auditioned ALOT of springs, including the stock Typhon 6s springs, which were WAY too soft.
Granite 3s front spring: 1.00N/mm (5.7 lb/in) https://www.arrma-rc.com/part/AR330538
Granite 3s rear spring: 0.84N/mm (4.7lb/in) https://www.arrma-rc.com/part/AR330539
Typhon 6s front spring: 0.74N/mm (4.23 lb/in) https://www.arrma-rc.com/part/AR330235
Typhon 6s rear spring: 0.55N/mm (3.17 lb/in) https://www.arrma-rc.com/part/AR330239
A thread for shock spring stiffness.
https://www.arrmaforum.com/threads/arrma-spring-list-chart-for-4s-and-most-6s-vehicles.18704/
jkflow added a nice conversion chart to make direct comparisons between N/mm, gf/mm, and lb/in.
P.S. The Associated RC8 Yellow springs are closest to stock Granite stiffness and I found them to be the best overall performers for a Granite with 16mm shocks. In the end, I'm using even stiffer springs for jumping, but the Associated Yellows performed better on the ground.
P.S.S. The stock shocks perform really well on the Granite. The main reason to upgrade is durability. If you're not breaking your shocks, using the pre-load collars to dial in performance may be your best bet.
I'm running just about the stiffest that will fit a Granite. Mojave ARA330639 shocks in front and Kraton/Outcast AR330507 in the rear. As I said in my previous post, the Associated RC8 Yellow springs are the best overall performers for a Granite with 16mm shocks. But I've seen your YouTube videos, you're a jumper like me (I also have the Typhon arms). The really stiff springs make all the difference in reducing bounce back from chassis slap and landing big jumps consistently.I’ve recently encountered this problem and wondering why I have to pet load my shocks so far. What springs would you recommend to replace the typhoon springs? What’s the stiffest you can use?
GRC, thanks for the awesome reply - very helpful. I am ordering the RC8 springs. Much appreciated!The Typhon shocks work well for a Granite because they have very similar length.
Either spring combo you are looking at will be better than the Typhon 6S springs. Typhon 6s springs are very soft.I've gotten my hands on the typhon shocks and I'm about to get the right springs (either the RC8 or the kraton/mojave springs).
Two questions:
First, what shock oil weight are people using? Mostly the same as the stock shocks?
Second, although I'll test this out myself soon enough, does the Granite act a bit more like an 8th scale vehicle with this shock upgrade? What I mean is that when i drive my 8th scale rigs off a normal jump (say, 6-8 feet of air) they just land like cats - the chassis does not hit the ground, there is no real rebound, and the truck keeps on going (if anything, you can even blip the throttle and accelerate hard because of the added downforce just after landing). My granite, however, tends to bottom out and then bounce off the ground when landing from the same (modest) jumps.
I doubt the 8th scale chassis aren't hitting the ground from 6-8 foot jumps. I think if you somehow had a slow-mo closeup camera you'd see they are slapping the chassis. The 3s line bounces because they're lighter. Stronger springs will definitely reduce bounce back, but it won't become a 6s rig. Once you stiffen the springs, you also have to use heavier oil to prevent the springs from rebounding too fast. I'm using 80wt, but didn't notice much of a difference from 60wt. It's the springs that make the main difference.Second, although I'll test this out myself soon enough, does the Granite act a bit more like an 8th scale vehicle with this shock upgrade? What I mean is that when i drive my 8th scale rigs off a normal jump (say, 6-8 feet of air) they just land like cats - the chassis does not hit the ground, there is no real rebound, and the truck keeps on going (if anything, you can even blip the throttle and accelerate hard because of the added downforce just after landing). My granite, however, tends to bottom out and then bounce off the ground when landing from the same (modest) jumps.
the preload should really be only used to keep spring from being loose when shock fully extended and to adjust ride height,Hey noob question here, but I'm confused about how the typhon shocks can work well for the Granite. Aren't the typhon shocks MUCH stiffer, since they're meant for a much heavier vehicle? I think the typhon shock springs are in the 6lb per inch range, and the shock oil must be heavier as well.
Thanks!
