Granite Arrma Granite Voltage -Upgrade Tires
Currently reading:
DixieDayDream
New Member
I have the smaller version of the Granite Voltage 4x4. And I'm wanting to upgrade my tires to be bigger. Mostly everything that was stock is upgraded. Anyone know what my limit on size I should go with that my Granite could handle? I can run up to a 3s battery.
Yonic
Tel Aviv, Israel
  2. Senton 3s
  3. Talion
  4. Typhon 6s
  5. Typhon 3s
  6. Voltage
i'm confused. you said granite voltage, that is a 2wd car, and then you said 4x4, which is not the voltage.. but a completely different car.
What car is it? the 4x4 or the 2wd?
GraniteFox
Delaware
  1. 4x4-Mega
  2. Granite
  3. Notorious
  4. Typhon 3s
Look for something cheap on amazon or save you money and pickup a BLX. If you like to work on RC cars there are used options on ebay that normally sell for about $250 ish. They normally need a little tlc to get up and running.
Jerry-rigged
Have you seen my LVC?
Texas, Baby!
  3. Outcast 6s
  4. Typhon 6s
For either the 2wd Voltage or the 4x4 Granite, stay with the 2.8MT tires. If voltage, you need 12mm hex, if 4x4, you need 14mm hex. Either way, if you want bigger than 2.8 tires, you will need to make the truck wider so the tire will clear the body and chassis.
