SOLD / FOUND Arrma HD Input Gear (17T) (ARA310773)
Status
Not open for further replies.
  1. 4x4-Mega
  2. Felony
  3. Mojave
  4. Senton 6s
Wanting to buy at least two of these ARA310773 . I have a few on backorder but now im in personal need of them so I need to outsource.
Let me know price with shipping unless local (most are probably not local to me in Arkansas).
nothing per se just wanting to keep it the same ratio haven't played with diff gearing much. But if its not a big difference in ratio then I deff will pick them up.
now with the 13t input if I had the diffs from a v3 would I essentially have the same ratio v3 at that point?
actually its been this long and so many things replaced the only thing I think left would be to get the v3 diffs and inputs I have the slipper and brushless system just avoided running it on 3s bc of the input gear. so then the 13t inputs are all i should need. or is there something im missing. its been a long day haha
Yeah the old mega ratio was 2.88, the current mega and 3s ratio is 2.85, so they are very close.
So yeah if you can't find the 17T HD inputs you can just get the 13T inputs and 37T diffs and be all set.
Diffs x 2:
https://jennysrc.com/collections/ar...tial-front-rear-37t-granite-big-rock-ar102668
Input set:
https://jennysrc.com/collections/ar...put-bevel-gears-13t-bearings-granite-ar102668
Status
