Tobbe Arnesson
Hi!
I've run the Infraction three times and all of them resulted in a heat cut off, before running out of juice (6S, 4 000 mAh).
I'm guessing air can't get through the body enough to cool things down, since all the electronics get hot.
After the second run I opened the two center "headlights" into holes, the two air intake scoops in the hood and also the two "holes" on each front fender.
It looks like the rear is open enough to let the air get out, unless there's some aerodynamic thing going on.
Still got the heat cut off today, but I was drifting around a wet 1:10 tarmac course, so not very high speeds - i.e. not much airflow.
It's been around 18-20 degrees Celsius (65-68 F), so far from hot.
I'll give it another go with the holes I have, or I might open up the whole front around the headlights and put in actual mesh.
Has anyone been successful in getting the temps down? Looking at heatsinks for the motor to increase its lifespan, but it won't stop the ESC from overheating.
Shame, since it's a blast to throw it around. ?
