Kraton Arrma karton 6s exb questions
flyxii
  1. Kraton EXB
I have been enjoying the kraton for a month, I made a m2c pattern plate because I noticed that my chassis was starting to bend, currently a piece of paper is going through [not too bad].
What else should I do to improve the model? What oils do you suggest for diff and shock for bash and jump? So far I have managed to break one rear lower arm and a shock bolt.
Is there anything else I should pay attention to?
On the kraton I turned the punch up from 5 to 7 on the kraton v6 pattern and the brake 50%, I use 16t pinion
Thanks !
I’ve changed the center diff form lsd to open with the Arrma diff kit and changed the center diff to 500k I also put nitro fuel tubing on the front shocks to help keep the cvds from popping out of the diff cups I’ve seen some take the spacer and red spacer off the arms for the hubs I also bought the garage life wheelie wing mount for it that’s bout all I’ve done along with the skid plate on the rear that the new v6 comes with
I have put the scorched rc rear skid plate on mine just wish it was a little longer :sneaky:
If you go to YouTube you a look up rc chassis brace K6, I bet something will show. This Company in Canada makes some. 🎯
Nice Chassis brace! I have been wanting to try making something similar but Santa did not bring a drill press or a big garage :LOL:.
Welcome to the forum, if you do some searching you will find a huge repository of threads discussing fluid weights and all kinds of mods and upgrades. I prefer the stock fluid weights for the shocks and for the diff's I like to up the weight a little, especially the center diff (500k to 1M-ish) for non LSD Diff setups.
The stock arms are pretty good, there is not much I would change on the EXB.
Emotion Greeting GIF by echilibrultau
The Scorched RC one is 🔥 Got one on a rig.
Today I made two jumps and the outdrive cup broke
Exactly on this side I broke my lower arm. Do you think it was already weakened or is it a coincidence?
