Kraton Arrma karton 6s exb questions
don't believe wind chill matters to a rig. Wind chill affects exposed skin. 707 flying at 30,000 ft in the cold going 500mph Will not have an effect. . But the cold will snap plastic, or metal on impact. 🔥 .
Today I made two jumps and the outdrive cup broke
Exactly on this side I broke my lower arm. Do you think it was already weakened or is it a coincidence?
Yeah you most likely cracked it when you broke the a arm and then it finished itself off when you jumped it.
I bought the Kraton 6s V6 the punch was set at 7 out of the box. My chassis is 7075 aluminum.
Thanks in advance
Next modifications:
Diff oil: F 50k C 500k open R 30k
rpm rear arms + m2c rear hinge pin 3615
Backflip tires
