Kraton Arrma kraton 4s slipper clutch issue
jondilly1974
Speed running apprentice, 3D printing fool
Toledo, OH
Granite, Kraton 4s, Typhon 6s, Typhon 3s
My slipper clutch keeps getting loose every run im quite tired really i tried locktite i tried sanding the spring nothing does it:/
Can you check the front side of the assembly and see if the bushing has snapped off? Mine did and couldn’t keep it tight, no matter what. I also snapped off the screw at one point trying to get it tighter and didn’t realize it. I’m waiting for a whole new assembly to arrive. I also upgraded to a steel spur and slipper pads from HR. Maybe they are to blame somewhat.
pl9171
Canada
Senton, Typhon 6s, Typhon 3s
Hi,
Humm... 4s is a lot of power for this slipper clutch (IMO)...
When we put MT wheels on the Mega BLX in 3s (on the pavement), full throttle, at the end of the session, the slipper clutch comes loose.
But we never had this problem on the track.
Loctite…? Really?
PL
jondilly1974
Toledo, OH
Hi,
Loctite…? Really?
PL
I blue loctite my slipper every single time. I e considered red loctite if I could dial it in perfectly.
jondilly1974
Toledo, OH
Did you let the loctite set for 24 hrs before you ran the truck again?
I do every time, but it still gets loose somehow. 🤷🏻‍♂️ I’m going to get the new assembly dialed in and red loctite that B.
Edit; I might even drill thru and make it a spool
MyZuC
Granite, Infraction, Limitless, Kraton 8S, Kraton 6s, Kraton 4s, Nero, Outcast 6s, Senton
I’m sick of ending runs due to this POS slipper 😂
I know the feeling. The first time mine started slipping, I loctited the adjustment screw and let it set a few days. Fingers crossed it hasn't needed adjusting for the last 7 batteries.
Canada 🇨🇦 Montreal
Kraton 4s, Typhon 3s
Everything seems fine3 little spacers with a spring
Yes
It kills my baterry
Kylerc
Mine had a ton of problems and actually melted a bunch of parts, but still usable. I found a steel locknut that fit and cranked it down as much as I could until I thought it would break and I haven’t messed with it since, I hope I don’t have to. It was tricky to fabricate but it works.
Now that I told someone it’s probably gonna break again because I thought it was acting up a little today. I hope not:mad:
jondilly1974
Toledo, OH
Okay i think the spring is stuck or doesn't do is job anymore i loose the slipper 1/2 turn and its completly loose
I need to loose it 1/10 turn to make it okay:/ should i contact horizon for this?
Check the inside of the front hub and see if the brass insert broke free. Mine did too.
Phil young
Granite, Kraton 4s
I have this problem and the only thing I can do is tighten it all the way. I tried factory setting which is 1 and 1/4 turns from tight and it kept going loose. I just stripped my input gear in the front diff. I don't know what to do.
Create account
Log in
