Kraton Arrma Kraton 4s Slipper Clutch Screw
Unlucky2001
Hello,
recently, I lost a lot of power to my front tires. So I took apart the gearing to see if there was anything wrong and the screw head for the slipper clutch broke off. Everywhere that I see the maintenance kits, they are on back order or out of stock. Is there anywhere that has it in stock? Or does anyone know the screw that is used?
Thank you,
Unlucky
You’re going to need some heat to get that screw out. Acetone helps a little too and works great for cleaning the threads. Make sure to get a 12.9 grade screw because a 10.9 will strip out or break right away and anything else is just mush.
Okay, thank you. I got the screw out last night, took some lovin lol.
