Thank you @IrieWheeler this is the most helpful advice I have received!Hi @mariniam and welcome to the madness!
Being new myself this has been an issue getting started also. The tray in the V2 Mojave has 48mm of width according to both my cars. Anything wider and you'll have to start chopping plastic and removing the slide retainer on the front of the battery tray. I have no idea how people are fitting larger batteries in otherwise.
Personally I have some of the Spektrum 3S 5000mAh "100C" packs and just got some of these 6S packs on good recommendation from a couple of experienced guys on here:
6S 4000mAh EC5 - 136mm x 42mm x 50mm
The 5000mAh are 155mm x 48mm x 45mm which I will buy after I've seen the 4000's that are guaranteed to fit.
The problem with ordering online is there is slight variations in dimensions of packs sometimes (which is why some put things like +/- 3mm, etc. in some listings) so buying a 48mm wide pack on the internet may turn-out to be a non-fitting 50mm when you get it? Make sense?
Anyway, I'd suggest you keep a conservative 46mm in mind as your maximum width for your packs unless you can look at and measure your packs before you buy. Finding appropriate batteries is an issue and requires some looking around but there are quite a few choices out there especially if you don't mind changing connectors on packs. Good luck and cheers
I was able to fit 2 of these in the stock battery tray on my Outcast 156x49x31.7mm https://hobbyking.com/en_us/rhino-5000mah-3s-50c-lipo-battery-pack-w-xt60.html so I'm sure you can shoehorn that beast in there. You might have to remove the retainer on the front of the tray though.Thank you @IrieWheeler this is the most helpful advice I have received!
Been searching for days to find the perfect high rated >80C 5000mah for my Arrmas and just can't seem to get one that fits unless I go down to 4k like you say.
But I took a risk today and pulled the trigger on what I know from experience to be the best lipo out there from my racing drone shenanigans
Tattu R-Line 22.2V 5100mah 6S 95C FPV
Its 49mm which is +1 from the allowed 48mm, but I'm confident I will get it to fit. If not I'll return it.
I measured a whole lot of Tattus I have sitting around and they are roughly 1-2 mm less that what is stated on their website.
Fingers crossed!
Well saidNothing wrong with them if you are new, they are more expensive compared to others of equal or similar performance. They take the maintenance worry out of the equation and that is what the are designed to do and do it well.
