Kraton Arrma kraton 6s v5
Derrick840
New Member
Best fluid for center diff most of the power is going to the front and would like suggestions on whats the best for making the power more even
What are you running in front and rear diff? Still 10k or also more?
I'm running 30k rear and 70k front. I found it handles a little better with the front heavier than the rear. I am still running the stock V3 tires so the traction is not as good as the later version tires.
Thanks for your replay @Soppy
Due to a fault myself (ordered WT instead of CST) I currently have 340k / 2100k / 340k inside. It works but, yeah, is not drive-able on high speeds :D
Will try once 70k/500k/50k.
I did 100k/500k/100k in my notorious. I had meant to put 50k in the rear but accidentaly put 100k and just said screw it lol You want heavier in the front to prevent wheelies
