How to shim the main input gear?!The problem on Myen was the main input gear (10 tooth)in front diff housing, installed new one and shimmed it.. good to go!
Hi
I had really bad grinding noise from my Kraton under hard acceleration and braking last weekend. I knew my diffs were in good shape because I only rebuilt and shimmed them and also changed bearings a few weeks ago. Took out the diffs and checked them and they were 100% perfect. Crown gear and input gear were also ok. Only other thing I could think of was the crown gear on the diff not meshing correctly with the input gear in the housing.
What I did was put a 0.050" thick washer between the crown gear and the bearing on the diff output drive. I added a few pics before during and after.View attachment 15179 View attachment 15180View attachment 15181 View attachment 15182
Did the same with the rear diff.
Tried a couple of test runs and drive train now seems solid. Not a hint of grinding. My only concern is that the washer may put additional stresses on the diff bearings and or the input drive bearing but time will tell.
"Red threadlocker on the grub screw just like the pinion and motor mount screws." - TBH I think blue thread lock is what I'd use. Unless you don't plan on disassembling again or have a better technique than me to loosen red locked screws/grubskrews.I also experienced the 'grinding' noise during breaking. I took apart the front diff to see what was going on. I inspected the gears and fluid since I had it ripped it apart and I was expecting to find missing teeth on the sun, planetary or input gears. Interestingly enough I was still getting seemingly full power to the front wheels. Turned out the front input drive cup was loose. I tightened it down with a generous amount of permatex red. Those drive cups are under a lot of torque and they need red threadlocker on the grub screw just like the pinion and motor mount screws.
under hard braking on cement kraton will make a grinding noise just under hard braking sounds plastic but I’m not sure any suggestions??
Check the main input gearI have the similar sound coming from my kraton v4 ??? and it is new...wtf...
