jmavrick0625
I have a 1 month Arrma Kraton, love it..
It is a beast. However the shaft on the motor broke, along with the pinion gear. Is the rotor and shaft easily replaceable? If so, where can I get this. I noticed Tower Hobbies has a Novak Rotor with 5mm shaft, part #LXEXJG....not sure if this will work??? If any RC gurus has an idea please let me know. Warranty might be out of the question, I took the rotor out of the motor already, not sure. Also since replacing the pinion gear can I run the 14 tooth gear in its place, I run on hard surfaces but also grass and light dirt.
