you can rebuild stock one for 15 bux.Hi all, I was wondering if I should just buy another stock servo because I completely stripped the stock one, or what would be a good aftermarket one that would just drop right in with no mods say max budget $40?
Thanks
-Spence
Yup, @spence unless you're just wanting to go with another brand the ADS-15M rebuilt kit would be a cheaper alternative.you can rebuild stock one for 15 bux.
Yes at 7.4 volts, at 6.0v stock esc bec they are both weaker, the because on blx185 is 6.0v even stock servo is not being used to its potential. I will be adding a mmx soon and wish I would have bought a different servo. sg1231 metal gear 444oz/in its taller than stock but it turns like a boss now. ebay for 69.99 new.https://hobbyking.com/en_us/trackst...y-monster-truck-servo-30-6kg-0-14sec-66g.html
Twice the torque of the standard servo which makes it much quicker to steer as it is not strained by the weight
Anyone use this servo? Is it a straight bolt on or does there need to be mods? I'm looking to try and keep the black/red scheme in the truck.https://hobbyking.com/en_us/trackst...y-monster-truck-servo-30-6kg-0-14sec-66g.html
Just to be clear. You are saying you wish you had bought a different one than the trackstar? The sg1231 is a good buy? I'm looking to upgrade. Thx for any advice.Yes at 7.4 volts, at 6.0v stock esc bec they are both weaker, the because on blx185 is 6.0v even stock servo is not being used to its potential. I will be adding a mmx soon and wish I would have bought a different servo. sg1231 metal gear 444oz/in its taller than stock but it turns like a boss now. ebay for 69.99 new.
I use this servo and it works great. Only fitting issue is that it is a little higher than the standard servo, couple of washers/spacer to raise it a touch and it will bolt straight in.Anyone use this servo? Is it a straight bolt on or does there need to be mods? I'm looking to try and keep the black/red scheme in the truck.
the servo you bought it still a great servo.ugh thanks for the suggestions guys but I just bought the sw0231, I wished I bought the rebuild kit![]()
I should get one for mine, should do the jobthanks, I will get that one![]()
I use the Savox 1210SG and it was plug and play. It is a little taller than the stock servo, so you will need to add spacers to lift the servo off the mount a little. And another spacer in the steering linkage. Also you have to take the top of the servo off to get it to fit in the GKA mount, due to the wires protruding from the middle of the servo opposed to the bottom. I guess you could do it all with the stock mount too.
