- Wisconsin
- Felony
- Fury
- Granite
- Infraction
- Limitless
- Kraton 8S
- Kraton 6s
- Kraton EXB
- Kraton 4s
- Nero
- Notorious
- Outcast 8s
- Outcast 4s
- Raider
- Senton 6s
- Talion
- Typhon 6s
- Vorteks
ARRMA-CUSTOM LIMITLESS TOYOTA GT1 (8S-ELECTRONICS) - NEW
- Specifications:
Drivetrain: 4WD (5mm) Shaft Drive
FANS: QUAD 40MM TORNADO FANS SET ON MOTOR
Final Drive Ratio: .85:1 Ratio with 34 tooth pinion and 29 tooth spur gear)
Max Battery Dimensions: 5.5 x 1.8 x 1.5 in. (139 x 46 x 39mm)
Motor Size: 4092-2300 KV Sensorless Brushless Motor (INCLUDED)
Motor Type: TP CM4060 Sensorless Brushless (INCLUDED)
Radio: FS-GT5 6CH RC Transmitter with FS BS6 Receiver(INCLUDED)
Servos: CLS6331 30KG High Torque RC Digital Servo (INCLUDED)
Shock Type: Big Bore aluminum body oil-filled
Size/Scale: 1/7
Speed Control: CASTLE CREATION XL2X 8S ESC (INCLUDED)
Suspension: Independent
Tire Compound: White compound
Tires: CONJB38B Contact GT8/Rally 1/8 On Road Foam GT Tires 38 Shore Black rims GRP
Vehicle Type: Speed bash on-road LIMITLESS roller chassis
Weight: 23 lbs (with batteries)
Wheel Diameter: 6.65" (169mm)
Wheel Hex Size: 17mm Hex
Wheel Type: Dish
Wheel Width: 3.62" (92mm)
Wheelbase: 14.84" (377mm)
Width: 18.15" (461mm)
Includes:1.) 1/7 LIMITLESS CHASSIS Speed Bash: Roller (ARA109011)3.) 2-PCS Turnigy PAPID 4S 5500mah 140C Lipo Batteries
2.) CASTLE CREATION XL2X 8S ESC (INCLUDED)
4.) TP 4060CM 4092-2300KV Sensorless Brushless Motor
5.) Steel Mod 1.0 34 TOOTH Pinion Gear / 29 TOOTH SPUR GEAR
6.) Racing Heat Sink with QUAD Tornado Electric High Speed Fans set for 1:8 Motors
7.) CLS6331 30KG Metal Gear High Torque Waterproof Digital Servo
8.) 6 PACK 15,200 UF CAPACITOR PACK (INCLUDED)9.) Fly Sky FS-GT3C Transmitter with GR3E 3-Channel Receiver (INCLUDED)
Needed to Complete:
AA ALKALINE BATTERIES FOR TRANSMITTER
WARNING
THIS IS NOT A TOY!
The special electronics and gearing in this ARRMA Limitless makes it a very powerful machine. It is capable in reaching speeds in excess of 100 mph and warrants special experience in handling it.
It is recommended that the operator start off with either a 4 cell or 6 cell battery and use caution in bringing it up to full speed before going the the 8 cell (maximum) battery.
Seller is not responsible for any property damage, equipment failure or personal injury due to the misuse of this product. Buyer uses at his or her own risk.
- (OR MAKE ME AN OFFER)
