I just pulled my front diff from my K6EXB for the first time. I've been running for almost a year now, never checked them out of the box. I know most recommend a teardown right out of the box, and I get it. I figure if something is a miss, it'll let me know. The diff has worked flawlessly, no clicking or skipping, just freewheeling a bit more than it used to..well, surprise, no oil. Wet, but no actual fluid. I should mention that both output shafts were pretty wiggly, alot of side to side movement. So, being the minimalist I am, fill and reassemble. Simple, right? Well, after doing so and tightening down the ring gear to the cup, it's bound up tight, weird, it was fine, all I did was fill with fluid and put it back together?
After taking it back apart, I find that there is literally no gasket between the ring gear and cup..they must've left the screws loose from the factory,LOL. That allowed the diff to work, and what little fluid that was in it leak out?
Interestingly, now that it's been sitting on the bench with 7k fluid in it, it's leaking out the bottom past the o ring.. simple refill eh?
