Big Rock Arrma Mojave V2 6s 4WD fan
Dan83
Any no what best fan to get for my arrma Mojave V2 6s 4WD has it just got delivered today
Welcome Dan83.
Fan for what, your motor?
Arrma sells a 35mm fan that attaches to the heatsink. The heatsink will likely retain more heat than it dissipates in my humble opinion and not having tried both options in a testing environment.
Most people, myself included, go with the Yeah Racing heatsink and dual fan setup. It fits loose on the stock motor so you need to use some thermal tape, split silicon tubing or other non-flamable stuff to shim around the motor where the heatsink comes into contact.
Don't forget to go over your diffs unless you don't mind just blowing one up to find-out it isn't shimmed properly.
Just had it out for 2nd run ran perfect absoulte machine seem to get bot 40 minutes to run time is rather about right
