ARRMA Notorious 6S build log & FULL UPGRADE LIST
Yas
UK
  1. Felony
  2. Mojave EXB
  3. Notorious
  4. Outcast 6s
  5. Typhon 3s
Since there's a giveaway there's not been a better time to start a build log for this big blue beasty. Owned from new since August 2019 and has been my favourite RC of 7 rigs to date
Full list of UPGRADES below! Feel free to ask for any part numbers. I can edit them in should anyone want me to ✌
CHASSIS & DRIVETRAIN
- Arrma 18/20t MOD1 pinion
- GPM aluminium front chassis brace
- GPM aluminium rear chassis brace
- GPM aluminium centre diff and motor mount
- GPM aluminium diff cups (F/R)
- GPM hardened steel diff set (only in rear diff)
- FastEddy sealed bearing kit (not needed any yet)
- Mugen Seiki diff shim set (for internal diff gears)
- Kyosho 8x12x0.2 shims (for diff input/pinion gear)
- CoreRC 13x16x0.2 shims (for diff ring/crown gear and centre diff)
- Team Associated 0.324x0.409x0.005 shims (for front and rear hub axles)
- Team Associated diff oils 100/500/30k cSt F/C/R
ELECTRONICS
- Hobbywing Max6 ESC combo w/4985 1650Kv Motor
- Savox 1210SG servo
- DX5 Rugged TX w/SR515 receiver
BODY & BUMPERS
- T-Bone Racing R1 Exo cage
- T-Bone Racing V2 Basher front bumper
- T-Bone Racing TCS chassis skid and vinyl w/front and rear skid plates [DISCONTINUED]
- T-Bone Racing rear bumper w/wheelie bar (unused, personal preference)
- RPM wing mount
- GPM aluminium body post mounts
SUSPENSION & STEERING
- Arrma Nero HD rod ends
- HoBao Hyper SS/Cage ball 6.8mm (for Nero rod ends)
- RPM front A arms
- RPM rear A arms
- RPM rear A arm mud guards
- T-Bone Racing rear A arm mud guards (unused, for spare stock A arms)
- GPM aluminium front shock tower
- GPM aluminium rear shock tower
- GPM aluminium front upper suspension mount
- GPM aluminium front lower suspension mounts
- GPM aluminium rear suspension mounts (unused, created A arm slop)
- GPM aluminium servo mount
- Arrma adjustable servo saver
- Rubber sealed steering post and bellcrank bearings
- Scorched Parts titanium steering rack
- Team Associated shock oils 3000/2000 cSt F/R
WHEELS & TYRES
- Arrma DBoots 3.8 Backflip LP tyres (unmounted, Gorilla tough and wide tape belted, vented)
- Arrma 3.8 17mm hex Outcast wheels (rims taped)
- Pro-Line 3.8 Shockwave tyres pre-mounted on 17mm hex F-11 1/2 offset wheels (rims taped, tyres vented)
- Pro-Line 3.8 Road Rage tyres pre-mounted on 17mm hex Desperado 1/2 offset wheels
Since there's a giveaway there's not a better time to start a build log for this big blue beasty. Owned from new since August 2019 and has been my favourite RC of 7 rigs to date
Full list of UPGRADES below! Feel free to ask for any part numbers. I can edit them in should anyone want me to ✌️
- Arrma 20t MOD1 pinion
- Team Associated 0.324x0.409 shims (for front and rear hub axles)
ELECTRONICS
- Hobbywing Max6 ESC combo w/ 4985 1650Kv Motor
BODY & BUMPERS
- T-Bone Racing TCS chassis skid and vinyl w/ front and rear skid plates [DISCONTINUED]
- T-Bone Racing rear bumper w/wheelie bar (unused)
- RPM wing mount
- RPM front A arms
- RPM rear A arms
- T-Bone Racing rear A arm mud guards (for spare stock arms)
WHEELS & TYRES
- Arrma DBoots 3.8 Backflip LP tyres (unmounted, Gorilla tough and wide tape belted)
Whoa whoa whoa, can’t post something that sounds so beautiful without pics man :) looks like a solid build! Nice work. Can’t wait to see it.
HW Max6 install and rebuild!
Stripped the entire rig down for a clean. All has been re-greased, re-shimmed, refilled and retuned. Just waiting on some tin/lead solder lost in the post for the ESC leads ?
Out with the old and in with the new
Had to cut out a notch in the side guard for the 4985 motor to fit
Can anyone recommend a new body I can paint up? I'd like a similar thickness and toughness as the stock one if possible
Nice and shiny centre diff ?
Does anybody else take over the dining room table when it comes to wrenching on RCs? ?
View attachment 82413View attachment 82414
View attachment 82415View attachment 82416View attachment 82417
That’s more like it ??. Very nice ride. You looking for another arrma body? Or something different?
Thanks buddy! Yes I'm thinking of painting one up. I've checked out a few Pro-Line clear truck bodies but I've heard mixed reviews. Have you had any experience with them? Do you know if they're as thick and tough as the Arrma ones?
To be honest with you, in my experience there is no thicker tougher body than the arrma bodies. The aftermarket ones seem to be thinner and not as tough. (Unless you go with the unbreakable ones). You could always get a clear outcast or notorious body and it will be as thick as your stock one. But clear so you can make it your own.
https://www.horizonhobby.com/ARAC33...eBf6c8Zb_vUkfGYCNBdcPqX-eUtnRFCBoCTboQAvD_BwE
https://www.horizonhobby.com/body-clear-outcast-arac3314
Awesome... I think I will actually. I love the Notorious body so I could just grab another. I'm thinking metallic silver with red trim and some matte black details. Thanks for the suggestion brother ?
I was just looking through your pics... and it looks like you had to do the same thing as me with that hobby wing heat sink... spread the crap out of it and then only 2 screws fit ??
Another Sweet build you gotta love this forum some really nice work goes on from bashing to blast here :)
I'd love to say it's all done and reveal the finished product!!
Only half way through the first coat the brand new spray can went kaput ? packed it all away and now I'm left waiting for another ?
Fell at the first hurdle ? and the masking took ages!!!
Are you going to try and mimick the "real steel" shell?
