ARRMA Notorious 6s build Log
I Beefed up my Notorious with some more #M2Cracing parts!
M2C 3035 REAR SHOCK TOWER BRACE (POLISHED)
M2C 3041 - REAR CENTER CHASSIS BRACE (POLISHED)
M2C 3047 - FRONT CENTER CHASSIS BRACE (POLISHED)
Today, I will be installing some upgrades since I have been running my Notorious w/ a RR 15T pinion and she flys like a rocket! ? ? ?
I actually beat my personal best today and topped out at 60 MPH! so thats what i am installing these fans!
Installed the #Yeahracing 30MM Booster fan on my 6s Notorious and it works awesome! Running a 16t pinion an she flys like a rocket and temps are under control now vs without my #Yeahracing fan! ? ? ? - PB is 59mph so far!!
Updating some parts on my #v4 Notorious!
don't BUY THESE SINCE THEY ARE JUNK
Hot Racing - AON3011M01 ALUMINUM Center Sway Bar Mounts
Installing a fan system in my 6s Notorious and will be adding small 900mAh 30C Lipo Battery to run it! I was currently am running a #Yeahracing 30MM Booster fan with a heatsink but I am not happy with the set up and my motor from time to time gets hot so I bought a new PG "IMPERVIOUS" Extreme (WATER RESISTANT) Cooling fans.. More pics to come.....
When ramp bashing and broke one GPM Racing rod end this past weekend. I tried to send them an email asking them if they would send me a new plastic elbow and they refused and wanted to charge me over 35.00 for an a-arm rod end so I am putting on my stock ones that came on the truck. NOT HAPPY W/ GPM RACING AND WOULD NOT ORDER ANY MORE PARTS FROM THEM....
Its finally time to buy a new body... I cant believe how long my stock one lasted which was close to a year and I bash pretty hard...
This time, I will be adding some dry wall tape and then I will use shoe goo to seal in the drywall tape and then spray 2 coats of Flexseal
for even more reinforcement ? ?
Going over my cars before this weekend and I noticed I have a cracked front right hub from one of these massive landing this animal took last weekend. Anyways, I had an extra set laying around in my stock pile of parts from - JennyRC.
Here is the part number that i replaced FYI!!!
NOTORIOUS 6S BLX - HUBS BEARINGS F/R UPRIGHTS V4 OUTCAST KRATON AR106044
When
Cool thanks. Yes I have the DumboRC X6A with adjustable gyro so I can do that. Good idea to have a set of road/speed tires.
When i BASH i like having on either set of Dboot Backflips on or my Proline Trenchers. In this video I have the BIG BOY TIREs ON!
