Raji
- Thread starter
- #41
This is what I ended up with for now. I had an old Syma quad which I cut the female adaptor off. I then spliced it into the Y harness. Next I cut the adaptors off both fans and spliced them to the harness. I used liquid electrical tape, heat shrinked it then regular electrical tape.
Right now I’m using a 3.7v 500mah battery which came from the Syma. I image they will last a while but I’m going to test it. I dipped the batteries in liquid electrical tape to waterproof them also. For now I secured the battery with a velcro command strip so I can pull it off to charge.
The reason I did this was I didn’t want to draw off the rc lipo and shorten run time.
How long 500 mah battery take with this fans?
