Senton Arrma senton 3s tire/wheel recommendation
short course basher
Arrma senton 3s tire/wheel recommendation left rear just blew out wondering if i should stick with the dboot fortresses or go with proline badlands i mostly race it on grass.
Also looking to put on typhon 3s linkage's and a-arms to improve stability wondering if i should put proline powestrokes on it which i can pick up for $60 for a set of 4 from a friend or would there be a better way to improve stability and control.
dboot fortress https://www.amazon.com/ARRMA-dBoots...517&sprefix=arrma+senton+tires,aps,191&sr=8-2
pro line badlands: https://www.amazon.com/Pro-line-Rac...7d64&pd_rd_i=B0875GNDP9&psc=1#customerReviews
I would say Badlands are probably the way to go.
Also, you may want to try the Granite tires.
The Badlands will definitely add grip and the Granite ones will make it drive like a Granite. Other then that not really
Buy a Skyrc gyo for $20. Works a treat on stability.
Remove the RX and place it 90 degrees to the left wall of the RX box.
You will need to grind down the screw tower by 3mm, but as its at the base it is not used to screw to the chassis or anything as the screw comes down from the ESC.
Match them all up before sticking down (3M VHB tape is best stuff)
You will need to tidy the wires up or things will get tight in the box.
where can you get that gyro for the best price on amazon it is $30
